How to make points visible?
khoshravan
I have used GeoBuilder's LISP routine to import points coordinates into CAD. Apparently it is done but I can't see the points.
How can I make them visible?
Also I expect after clicking OK, a line connecting the point, appears but nothing happens. ACAD only construct the layers. How can I make points visible?
I also asked same question in the original thread of
Import coordinates from a text file txt in AutoCAD 14th Sep. 2012
This may work , but make sure that you have all your layers unlocked first .
(defun c:PTvis (/ s i e)
 (if (setq s (ssget "_x" '((0 . "POINT") (60 . 1))))
   (repeat (setq i (sslength s))
     (setq e (entget (ssname s (setq i (1- i)))))
     (if (not (assoc 60 e))
       (entmod (append e (list (cons 60 0))))
       (entmod (subst (cons 60 0) (assoc 60 e) e))
@Tharwat, that could be shortened to:
(defun c:showpoints ( / i s )
   (if (setq s (ssget "_X" '((0 . "POINT") (60 . 1))))
           (entmod (append (entget (ssname s (setq i (1- i)))) '((60 . 0))))
After this (above posted codes), you may want to check point style that is currently active... Maybe that's why you don't see points in the first place... Change PDMODE sysvar...
M.R.
Sorry if my question sounds too novice.
I copied above code into wordpad and saved it with lsp and vlx extensions and named it showpoint.
Inside cad, I used appload command to load above routines. in the bottom it shows that both are loaded successfully.
But when I type showpoint in cad, it says unknown command.
How can I use these routines?
