Ahmeds Posted January 27, 2013 Posted January 27, 2013 (edited) Hello guys, can someone make this for me? Let's say I start with what is shown in circle #1. What I want the results of this custom lisp routine to look like Circle # 2 after it is run but not cutting any lines inside it but just masking it and putting circle in another layer. Thanks. Edited January 29, 2013 by Ahmeds Quote
nod684 Posted January 30, 2013 Posted January 30, 2013 Maybe Lee Mac's Circular Wipeout can help Quote
Ahmeds Posted January 30, 2013 Author Posted January 30, 2013 Maybe Lee Mac's Circular Wipeout can help Thanks nod, I would love to try it. Quote
Lee Mac Posted January 30, 2013 Posted January 30, 2013 Thanks for the recommendation nod The program is also available on my site since you may need membership to view that area of TheSwamp. Quote
Ahmeds Posted January 31, 2013 Author Posted January 31, 2013 I already tried the Circular Wipeout found from TheSwamp, and I am using it now instead of the one in Lee's site.. Lee, I run the routine and it is so useful to me but with some modification makes a lot better if that Circular Wipeout could work not only in one selected circle but all circles within the layer.. how could it be? Quote
Tharwat Posted January 31, 2013 Posted January 31, 2013 ... but with some modification makes a lot better if that Circular Wipeout could work not only in one selected circle but all circles within the layer.. how could it be? Try this code and let me know how things are going on with you . (defun c:Test (/ *error* ss i sn st le di lst e) ;;; Tharwat 31. jan. 2013 ;;; ;;; Wipeout circles ;;; (vl-load-com) (defun *error* (x) (if cm (setvar 'cmdecho cm) ) (princ "\n *Cancel*") ) (or Doc (setq Doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (if (progn (print "Select Circles to Wipeout ...") (setq ss (ssget "_:L" '((0 . "CIRCLE"))))) (progn (setq cm (getvar 'cmdecho)) (setvar 'cmdecho 0) (vla-StartUndoMark Doc) (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i))) st (vlax-curve-getstartpoint sn) le (/ (* pi (* (cdr (assoc 40 (entget sn))) 2.)) 50.) di le lst nil ) (repeat 50 (setq lst (cons (vlax-curve-getpointatdist sn di) lst)) (setq di (+ di le))) (setq e (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)) '(70 . 1) ) (mapcar '(lambda (p) (cons 10 (list (car p) (cadr p)))) lst) ) ) ) (command "_.wipeout" "_p" e "y") (entdel sn) ) (setvar 'cmdecho cm) (vla-EndUndomark Doc) ) ) (princ "\n Written by Tharwat Al Shoufi") (princ) ) Quote
Lee Mac Posted February 3, 2013 Posted February 3, 2013 I have now updated my Circular Wipeout program to include a new command, c2wipe, to allow the user to convert existing circles to circular wipeouts, whilst retaining all original properties (such as Layer, Linetype, Lineweight etc.) of the existing circles. Quote
