Understanding the 'if' function.
Reu
(defun gp:getPointInput	(/ StartPt EndPt HalfWidth)
  (if (setq StartPt (getpoint "\nStart point of path: "))
  (if (setq EndPt (getpoint StartPt "\nEndpoint of path: "))
  (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: "))
T
I thought the syntax for the if function was:
(if (test expression)
(expression) (optional expression)
What is the purpose of using 'if' in the above code?
The intent may be clearer with better indentation:
(defun gp:getPointInput ( / StartPt EndPt HalfWidth )
               T
Here, the 'then' expressions for the first and second if statements are the second and third if statements respectively; though, the code is rather pointless since the 'then' expression for the final if statement is simply returning a boolean true value without using the collected points and distance values.
;;; Function gp:getPointInput will get path location and size
(list StartPt EndPt HalfWidth)
This is better? I've recently discovered the AutoLISP tutorial (that is where the code is from. I was asking about 'if' used as shown above because I have seen it so done before and wondered why. It didn't make sense when I was looking for something like:
(if (this statement is true)
(do this)
(else do this)
So essentially the 'test expression' for the first 'if' is "(getpoint "\nStart point of path: ")", the 'expression' to be evaluated if the 'test expression' returns a non-nil value is "(setq StartPt)", and the 'else' expression would be anything done by the user (eg. pressing 'Enter') that returns a nil value.
Am I correct?
Lee Mac just formatted your code excerpt to help you understand the logical succession. I will try to add comments to it, maybe this will help you more:
(defun gp:getPointInput ( / StartPt EndPt HalfWidth)
(if (setq StartPt (getpoint "\nStart point of path: "))           ;1
 (if (setq EndPt (getpoint StartPt "\nEndpoint of path: "))       ;2
  (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: "))   ;3
   (list StartPt EndPt HalfWidth)                                 ;4
  1. test if user picked a point or entered a set of coordinates; if succesful, go to next test.
  2. test if user picked another point or entered a set of coordinates; if succesful, go to next test.
  3. test if user picked a point (AutoCAD return measured distance between second point and current pick) or inputted a distance (numerical value).
  4. if all three above inputs were valid (all tests were passed) the routine return a list with 1st and 2nd point, respectively the numerical value.
Mybe this formatting make more sense for you?
(if (and (setq StartPt (getpoint "\nStart point of path: "))
         (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")))
I also annotated your code analisys:
So essentially the 'test expression' for the first 'if' is "(getpoint "\nStart point of path: ")" [true], the 'expression' to be evaluated if the 'test expression' returns a non-nil value is "(setq StartPt)", a new input test and the 'else' expression swould be anything done by the user (eg. pressing 'Enter') that returns a nil value. is not present into this piece of code; it does nothing if input is invalid or cancelled (more precisely the routine will return nil).
Yes, thanks.
So when you do multiple 'if' statements it is the same thing as a single 'if' statement with multiple 'and' test expressions.
There is a difference; using nested IF's will be able to define a specific action for each invalid input, while combining the tests with AND the action will be common. Please test in VLISP Console the two excerpts of code below:
(if (setq var1st (getint "\nFirst number: "))
(if (setq var2nd (getint "\nSecond number: "))
 (alert "All inputs valid!")
 (alert "No 2nd input!")
(alert "No 1st input!")
(if (and (setq var1st (getint "\nFirst number: "))
        (setq var2nd (getint "\nSecond number: ")))
(alert "No inputs!")
