unit (SI) keeps coming back to INCHES
spiderdian
 Share
i am deriving plates from a solid model (which is set to millimeters). on the sketch, i project geometry and finish the sketch (as we normally do). then when i extrude, i always get INCHES as the unit of extrusion. of course, its easy to just type in mm, but i am wondering why this sort of things happens and what the solution will. please help!
You need to set your default Standard.ipt file to metric units.
To fix your current file go to Tools>Document Setting>Units and set to metric.
It can't come back if the Standard template is fixed.
It sounds like you haven't done as instructed.
Attach your file here.
Do you have your Standard.* templates in the default location?
Do you have your *.ipj pointing to that location (or to new location if using other path)?
 Share
