I have limited experience in writing Macros within CUI. Mostly i have customized some commands to get what I need.
I was trying to modify the CLOSEALL command so that it will close all of the files open without saving.
My attempt: ^C^C_closeall;N
This did not work. I was still prompted Yes or No.
I also tried : ^C^C_closeall^I;N
I was hoping that when asked Yes or No, it would tab over and then answer No and subsequently close.
Again, no success.
A little background. I need to DXFOUT several files. Sometimes 50+. When doing so, when i normally CLOSEALL, I am prompted for each .dxf that was created if I want to save it. Since it is already saved in the folder in which the .dwg's are in, there is no reason to have to save. Therefore, I have to click "YES" 50+ times. Not the end of the world, but if there is a better way to close all of the files instantly, that would be great.
Basically, I would like to manipulate the CLOSEALL icon to do what I am asking. Certainly a potential dangerous command, but one that would be certainly useful at times.
Any help would be greatly appreciated!
A different tack why not have a lisp that picks the required files creates a script which opens, dxfout then closes each dwg rather than open all much faster and safer with regards to memory problems. Lee-mac has a script create
After posting this, I started reading about Scripts and AutoLisps and went to Lee Mac's website. Looks like it can really help me. i will definitely take that route.
Thanks!
