Using Blue Marble Global Mapper I created a .gen file for contour lines. I need to import this information into AutoCAD and I had assumed that I would use Map Import but it doesn't recognize the .gen file and therefore won't import the data.
Any help is greatly appreciated.
Also, is this the correct place to post this question?
Thank you, I will look into MapWorks Base.
