I just installed AutoCAD 2010 on Windows 7 (both 64-bit). There is a problem with the Page Setup Manager. When I select any of the page setup tabs, then select "modify" or even "new", the program crashes. Same things happens when I gain access to the Page Set Up Manager through the menu. . Page Manager hasn't ever worked. Update 2 is installed. I have repaired and reinstalled, and tried all again just now. There is no error message beyond "not responding" in parentheses next to name of dialogue box. The screen grays out and stays that way. Then the screen becomes shaded with the whirling aqua ring and it's all over. Control + P and plot causes the system to crash as well.
Any suggestions would be welcomed. Thanks in advance.
Could be printer driver related. Do you have any issues plotting drawings? If you have network printers make sure the the drivers on both machines match the driver on the network printers
