reyna12 Posted May 2, 2013 Share Posted May 2, 2013 Hi there, I'm pretty new to AutoCAD, I'm in fact just learning it for my studies. Now I've managed to "design" a bridge and add textures etc.. Nothing as fancy as what most of you might be able to create but still learning. Now, what i was looking to do, was print off 2D elevation and plan views of the bridge, but unfortunately the result is awful. Any tips? Please see attached images. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2013 Share Posted May 2, 2013 First I would get rid of the gadawful grid. What visual style did you use? Quote Link to comment Share on other sites More sharing options...
reyna12 Posted May 2, 2013 Author Share Posted May 2, 2013 That's just a screenshot of the program rather than the output render. The 3D wireframe view seems to be a bit better but still not great Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2013 Share Posted May 2, 2013 If all you want is 2D output then take a look at using Flatshot, SolProf, SectionPlane or BaseView. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 2, 2013 Share Posted May 2, 2013 Or better yet - viewbase command. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2013 Share Posted May 2, 2013 (edited) Funny, on the Ribbon it is referred to as Base View (3D Modelling workspace > Annotate tab > Drawing Views panel) but the command is ViewBase. AutoDesk programmers...gotta love their sense of ??? Edited May 2, 2013 by ReMark removed one space Quote Link to comment Share on other sites More sharing options...
reyna12 Posted May 2, 2013 Author Share Posted May 2, 2013 Yeah i got it eventually. Although all it did was this? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 2, 2013 Share Posted May 2, 2013 It looks like you did not let the command finish its work. If you had this is what you text screen should have shown. Command: viewbase Specify model source [Model space/File] : Type = Base and Projected Hidden Lines = Visible and hidden lines Scale = 1:2 Specify location of base view or [Type/sElect/Orientation/Hidden lines/Scale/Visibility] : Select option [sElect/Orientation/Hidden lines/Scale/Visibility/Move/eXit] : Specify location of projected view or : Base view created successfully. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 2, 2013 Share Posted May 2, 2013 .... the command is View Base. AutoDesk programmers...gotta love their sense of ??? Actually the command is viewbase as one "word". Software programs are particular like that. Quote Link to comment Share on other sites More sharing options...
