JamFam
Block creation help
JamFam
I'm working with Autocad 2011. My objective is to create a dynamic block made up of a circle with a letter or number inside. Here's the tricky part. As I add additional letters or numbers the circle increases in diameter automatically to fully encircle whatever it is I type. The more letters or numbers the larger the circle and the fewer the letters or numbers the smaller the circle? Can you help?
Or is there a lisp routine for this type of request?
Thanks
Share this post
Link to post
edwinprakoso
Dynamic block can't just resize object automatically. It needs user interaction.
You can scale the circle using scale action, but it won't be automatic.
Share this post
Link to post
Murph_map
Take a look at the Express tool named "Tcircle" it will draw a circle around text no matter what length the text is. Also let you use a rectangle and more options as to the offset and etc.
Share this post
Link to post
JamFam
Thanks for getting back. I will look at the Express Tool.
Share this post
Link to post
Mike_Taylor
If the dimensional constraints can pick up nodes on the text you may be able to add a dimensional constrain there.
Share this post
Link to post
JamFam
I like the T circle command if that's the best anyone can come up with.Hi Mike. I'm not following you, sorry. Please explain further.
Thanks
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
