I'm trying to linking a string with real value that is in a variable, but is giving error.
Can you help me?
The little lisp only divides two numbers and displays the prompt informed with the mark.
(defun c: split ()
(setq n1 (getreal "\ nPlease enter the first value ...:"); First value
      n2 (getreal "\ nEnter the second value ...:"); According Value
      result (/ n1 n2); Results of n1 divided by n2
realstring (rtos x result)); convert the result that is real to string
     result2 (strcat "Result:" realstring);link texts
       (print result2); displaying the value
Thank in advance
(defun c:split ( / m n )
   (if
       (and
           (setq m (getreal "\n1st value:"))
           (setq n (getreal "\n2nd value:"))
       (princ (strcat "\nResult: " (rtos (/ m n) 2)))
I will put also a conditon for:
(/= n 0)
Madruga_SP, in order to see the issues in your code:
(defun [color=red]c:split[/color]()
realstring (rtos [color=red][s]x[/s][/color] result)[color=red][s])[/s][/color]; convert the result that is real to string
     result2 (strcat "Result:" realstring)[color=red])[/color];link texts
