diggerlover Posted June 18, 2013 Share Posted June 18, 2013 Good afternoon all, Newbie to the forum but have been referencing it for years and usually found my answers. Currently using AutoCAD Mechanical 2012. My issue: Have recently used FARO tracker and have been left with an IGES file. When trying to import using. INSERT > EXTERNAL FILE > IGES. I have no navigation box to navigate to the file location. Instead i have - IGES Filemane: appears in the command bar. Is there a global setting that has somehow dropped off? I gave the file to a colleague on USB who used INSERT > EXTERNAL FILE > IGES. His navigation box appeared as you would expect. Any advice would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 18, 2013 Share Posted June 18, 2013 Filedia = 1 Quote Link to comment Share on other sites More sharing options...
diggerlover Posted June 18, 2013 Author Share Posted June 18, 2013 Hi, Thanks for the post... This doesn't seem to have worked either. I'm wondering if a reinstall might be reqd. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 18, 2013 Share Posted June 18, 2013 Try CMDDIA = 1 Quote Link to comment Share on other sites More sharing options...
diggerlover Posted June 19, 2013 Author Share Posted June 19, 2013 BINGO... Many thanks SLW210..... Regards. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 19, 2013 Share Posted June 19, 2013 You are welcome! I should have given both originally. Quote Link to comment Share on other sites More sharing options...
