Luís Augusto
Routine modification Dims2Field
Luís Augusto
In looking for a lisp routine that performs the sum selected dimensions, found one that I believe to be ideal for my work.
Could the author or another member of the forum to make a change?
It would be ideal for me to make the sum property>%). TextOverride>% Rotated Dimension object.
I tried to make the change but as I am not aware that language still did not succeed. Returns the error "misplaced dot on input".
Below the original routine.
Dims2Field.lsp
(defun c:Dims2Field ( / *error* spc doc pt uFlag ss ids )
(vl-load-com)
;; © Lee Mac 2010
(defun *error* ( msg )
(and uFlag (vla-EndUndomark doc))
(princ (strcat "\n** Error: " msg " **")))
(setq spc
(if
(or
(eq AcModelSpace
(vla-get-ActiveSpace
(setq doc
(vla-get-ActiveDocument
(vlax-get-acad-object)
(eq :vlax-true (vla-get-MSpace doc))
(vla-get-ModelSpace doc)
(vla-get-PaperSpace doc)
(if (and (ssget '((0 . "*DIMENSION")))
(setq pt (getpoint "\nPick Point for Field: ")))
(setq uFlag (not (vla-StartUndoMark doc)))
(vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc))
(setq Ids
(cons (GetObjectID obj doc) Ids)
(vla-delete ss)
(vla-AddMText spc (vlax-3D-point pt) 0.
(if (= 1 (length Ids))
(strcat "%<\\AcObjProp Object(%<\\_ObjId " (car Ids) ">%).Measurement \\f \"%lu6\">%")
(strcat "%<\\AcExpr"
(lst->str Ids " %<\\AcObjProp Object(%<\\_ObjId " ">%).Measurement >% +")
">%).Measurement >% \\f \"%lu6\">%"
(setq uFlag (vla-EndUndomark doc))
(defun lst->str ( lst d1 d2 )
;; © Lee Mac 2010
(if (cdr lst)
(strcat d1 (car lst) d2 (lst->str (cdr lst) d1 d2))
(strcat d1 (car lst))
(defun GetObjectID ( obj doc )
;; © Lee Mac 2010
(if
(eq "X64"
(strcase
(getenv "PROCESSOR_ARCHITECTURE")
(vlax-invoke-method
(vla-get-Utility doc) 'GetObjectIdString obj :vlax-false
(itoa (vla-get-Objectid obj))
Thank in advanced.
Luis Augusto.
Share this post
Link to post
ReMark
We'll give this thread a *bump* and see if it draws any response. Good luck.
Share this post
Link to post
