jongor Posted September 15, 2013 Author Share Posted September 15, 2013 So, using the help and methods from you guys here I've muddled my way through and created a nice smooth radius edge on this next body. I did it by using Loft between arcs that I measured along the outline, which created a surface. How can make the surface, and the hollow area under it a solid so it can be Unioned to the rest of the body? Please see attached. thanks! 3d Std J body-new.zip Quote Link to comment Share on other sites More sharing options...
