Tad_Thurston Posted July 15, 2013 Share Posted July 15, 2013 When going from ACAD Civil 3d 2011 to Civil 3d 2013, my mouse middle button (scroll button) stopped working correctly. I have verified that it still works properly in the 2011 version. Before the software upgrade, rolling the middle button zoomed and if I clicked and held down the middle button and moved the mouse, that would pan. This was very efficient because you can zoom and pan all with one button. These are 2 things a drafter must continually do while drawing. Now, after the upgrade, I get a menu if I click the middle button. Very frustrating. Why would the newer ACAD version change something like that? I verified that the CUI mouse button assignments are exactly equal between the 2 versions. The only other mouse control is the Windows mouse control and I have not changed those settings. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Tad_Thurston Posted July 15, 2013 Author Share Posted July 15, 2013 Never mind! I found out it was the MBUTTONPAN command and you set that to 1. My IT department came through for me. Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 16, 2013 Share Posted July 16, 2013 Never mind! I found out it was the MBUTTONPAN command and you set that to 1. My IT department came through for me. I believe mbuttompan is among the customizations that should have been exported from the old version and imported into the new version. I want to guess it is in the workspace customizations. Your IT department may have been backfilling for their own mistakes. and you may yet find more. I just recently had to chase my IT guys around the room with a big stick because they forgot to migrate any customizations from my old 2008 version up to an install for AutoCAD 2014. Thankfully we are running them parallel so I could retrieve the stuff myself. Quote Link to comment Share on other sites More sharing options...
