How to convert layer colour properties on multiple drawings quickly?
misskiti
Hi all,
I have 4500 OS mapping tiles which i need to convert the colours to one single colour rather than the varied layer colours they have at present. Obvioulsy doing this manually will take a long time. Is there a quicker way of doing this?
Many thanks for your help.
K
It sounds like a job for a batch processing script file. The script would open the drawing, make the layer colour changes, save and close the drawing then continue to repeat the process until all drawings have been processed.
Edited by ReMark
Ok thanks ReMark... I have seen a programme called ScriptPro mentioned elsewhere though i've not got admin rights so can't install that without authorisation from our lovely IT department. I don't have any experience of using scripts so was hoping this is something others may have come across before :unsure:
Yes, there is the free ScriptPro available from AutoDesk.
Another option: Script Writer by CADTutor member Lee Mac available via the link below.
http://lee-mac.com/scriptwriter.html
Lee has also been kind enough to create a tutorial called "An Introduction to Script Writing" that is referenced on the same page.
A simple example of a script. This one opens a drawing named chglaytest located on drive C:, executes a zoom > all, invokes the layer command, changes the layer color to 2 (yellow) for all (*) layers. It then saves the drawing and closes it.
_open
C:\chglaytest.dwg
_zoom a
_layer
C
2
save
Y
close
  • 4 weeks later...
Hi again,
I have run the above script and it works, thanks for your help.
However i have two issues now: the first is that it seems there are a few blocks contained within the drawings which the script does not change. Is there a way of writing something into the script to also change the colour of these?
The second is that the above script requires each drawing to be opened within autocad for the changes to be made. As i am on a very old machine this is going to take a very long time (i calculated about 45hours based on the test i did!) I have read elsewhere that there is a way of running scripts on drawings without them being opened in the drawing editor, and that this is much quicker. Does anyone know how to do this?
Thanks again for your help.
K
