kallerman
assigning easting & northing coordinates to origin
kallerman
hi
is it possible to assign easting & northing coordinates(gps coordinates) to origin or any other point in drawing so that i can find the others with respect to that?
if possible plz help..
Share this post
Link to post
Murph_map
In 2010 version you need the Google Earth add-on from Autodesk Labs that is no longer availalbe for down load. With newer versions of AutoCAD (2014) there is a geolocation tool. Or if you use Autocad map3d or Civil3D its build in. Keep in mind if you are using sports grade GPS that the output is in Lat/Lon.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
