Can Inventor tell me the machining time needed for my part?
zmarcoz
I read Wikipedia. It mentions machinability of different material.
Assume I have a part that need to put into a CNC machine, base on the table of "Cutting speeds for various materials using a plain high speed steel cutter" http://en.wikipedia.org/wiki/Speeds_and_feeds . I should be able to calculate the ideal time of cutting my part using CNC machine.
Does inventor have this feature?
So - you want to do CAD/CAM.
Inventor is the CAD side of that (Computer Aided Design).
You need the CAM side to find the information you are after (Computer Aided Manufacture).
Try this software https://beta.autodesk.com/callout/?callid=22396638F5374AC28E2F1A24CC7EEFA8
it works with Inventor. I am not sure how full-featured this free version is.
If it doesn't give machining time then check out a program like MasterCAM.
