DWG to PDF file location
SamIreland
Hi there,
I want to plot 100+ drawings to PDF's and was wondering if there is a way to change the base file location it saves, to a location I can choose? I am currently using the PDF to DWG.pc3 file in a plotting script. Is there also a way to get rid of the PDF viewer when the script is running?
Thanks :D
  • 3 weeks later...
Is there a way to implement using SSM in a script? I am working for a company that uses A3 plotting scripts and they have to use DWG to PDF.pc3 setting. I am also having a problem with opening the pdf viewer on plotting, I know there is a way to change this setting in the pc3 file but it doesn't want to co-operate with the script when it is running. Any help will be greatly appreciated.
