HeatherCee
I'm sure this has been asked before but I can't find it
HeatherCee
I am trying to add a block to my tool palette. I am able to add it, but when I click on the palette to add it to a drawing, it acts like it's going to work but nothing shows up in the drawing. I have added it to the source drawing, saved the source drawing, dragged it into the palette. All is well until I try to place it in a drawing. The other blocks work fine.
Any ideas?
Thanks much!
Share this post
Link to post
ReMark
No error message?
Could be a problem with a path.
Share this post
Link to post
Tharwat
Maybe something related to the layer status ? Off / Frozen that the contents of the block is related to , just a guess :)
Share this post
Link to post
HeatherCee
Nope, no error message. I checked the path and it matches the ones that do work.
Share this post
Link to post
HeatherCee
Not a frozen layer. Thanks, though!
Share this post
Link to post
Tharwat
Units of the Block ?
Share this post
Link to post
HeatherCee
:unsure: Not sure what that means..?
Incidentally, this is a new computer. It all worked fine on my old one.
Share this post
Link to post
Tharwat
Units = The units that the block drawn with Millimeters , Centimeters , Meters , Inches .... etc .
Then check if the insunits (system variable ) is matching the units of the Block on insertion .
Share this post
Link to post
HeatherCee
Well, I found I have indeed been placing them wayyyyy away from where I intended. So now I just have to figure out how to make them place where I put them. Thanks anyway, y'all.
Share this post
Link to post
ReMark
Sounds like when you created the block you specified 0,0,0 as the basepoint instead of picking somewhere on the geometry of the block itself.
Share this post
Link to post
Tharwat
Change the base point of the block to replace a new insertion point from the Block Editor .
Share this post
Link to post
HeatherCee
:DEureka! It worked! Thank you thank you thank you, both!
Share this post
Link to post
Tharwat
You're welcome , but what do you mean by Eureka ? :D
Share this post
Link to post
HeatherCee
It is just a word used to celebrate a discovery or invention of some sort. Like "I got it!"
Share this post
Link to post
Tharwat
Okay ,
Good luck . :)
Share this post
Link to post
ReMark
Look up Archimedes and the phrase "the volume of water displaced."
Share this post
Link to post
Tharwat
Waw I have just remembered that marvelous story about Archimedes , he is the one who said that word " eureka eureka " which means I found I found it . :lol:
Thank you .
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
