Taminsin Posted August 16, 2013 Share Posted August 16, 2013 Hello I am quite new to 3D autocad and have a problem with disappearing materials on the surface of my 3D models. I spend hours adding materials and colour to my drawings using the 'ctrl' select option on the surface of 3D objects, but when I save the drawing and go back to it another time the materials seem to disappear. This wouldn't be a problem if the drawing weren't so large, but it is a pain in the ass to keep repeating the same process which takes and long time. Thank you Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 18, 2013 Share Posted August 18, 2013 Once you apply a texture/material to an object it should stay put unless you are moving files around to different folder locations or renaming folders while the drawing is closed. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 19, 2013 Share Posted August 19, 2013 Can you post a drawing that has this occurring? Quote Link to comment Share on other sites More sharing options...
