Measure or Divide object - without use aligned distance...
Guys,
I'm curious, somebody know how to use the commands: Measure or Divide.
I need to distribute a block in one traced line, but with the same space betwen them, these commands put the distance, so, when the object that is the reference got a inclination the distance follow the object but the final distance has a litle mistake because degree of inclination... below I'm showing in some pictures what I'm trying to explain, someone knows one LISP code that can help?
Thanks...
Edited by CafeJr
Link to post
Try this quick hack:
([color=BLUE]defun[/color] c:mymeasure ( [color=BLUE]/[/color] di en in ln ob p1 p2 sn sp x1 )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color]
           ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] en ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect object to measure: "[/color])))
           ([color=BLUE]cond[/color]
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] en))
                   ([color=BLUE]if[/color] ([color=BLUE]vl-catch-all-error-p[/color] ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vlax-curve-getendparam[/color] ([color=BLUE]list[/color] en)))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nInvalid object selected."[/color])
   ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] en))
               ([color=BLUE]initget[/color] 6)
               ([color=BLUE]setq[/color] di ([color=BLUE]getdist[/color] [color=MAROON]"\nSpecify length of segment: "[/color]))
           ([color=BLUE]setq[/color] p1 ([color=BLUE]vlax-curve-getstartpoint[/color] en)
                 p2 ([color=BLUE]vlax-curve-getendpoint[/color]   en)
                 x1 ([color=BLUE]abs[/color] ([color=BLUE]-[/color] ([color=BLUE]car[/color] p2) ([color=BLUE]car[/color] p1)))
                 sn ([color=BLUE]fix[/color] ([color=BLUE]/[/color] x1 di))
                 x1 ([color=BLUE]+[/color] ([color=BLUE]min[/color] ([color=BLUE]car[/color] p1) ([color=BLUE]car[/color] p2)) ([color=BLUE]/[/color] ([color=BLUE]-[/color] x1 ([color=BLUE]*[/color] di sn)) 2.0))
                 ob ([color=BLUE]vlax-ename->vla-object[/color] en)
                 sp ([color=BLUE]vlax-get-property[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
                        ([color=BLUE]if[/color] ([color=BLUE]=[/color] 1 ([color=BLUE]getvar[/color] 'cvport))
                            'paperspace
                            'modelspace
           ([color=BLUE]repeat[/color] ([color=BLUE]1+[/color] sn)
               ([color=BLUE]setq[/color] ln ([color=BLUE]vlax-invoke[/color] sp 'addline ([color=BLUE]list[/color] x1 0.0 0.0) ([color=BLUE]list[/color] x1 1.0 0.0)))
               ([color=BLUE]if[/color] ([color=BLUE]setq[/color] in ([color=BLUE]vlax-invoke[/color] ob 'intersectwith ln [color=BLUE]acextendotherentity[/color]))
                   ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"POINT"[/color]) ([color=BLUE]list[/color] 10 ([color=BLUE]car[/color] in) ([color=BLUE]cadr[/color] in) ([color=BLUE]caddr[/color] in))))
               ([color=BLUE]vla-delete[/color] ln)
               ([color=BLUE]setq[/color] x1 ([color=BLUE]+[/color] x1 di))
   ([color=BLUE]princ[/color])
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Link to post
:thumbsup: Wowwwwwww... Thank you a lot "Lee Mac"!... It's exactly that I need!... I just need to exchange the point name to a block to be more fast on my application!... But it help me a lot!!!...
Link to post
You're welcome :)
Try the following, change the highlighted block name to suit:
([color=BLUE]defun[/color] c:mymeasure ( [color=BLUE]/[/color] *error* bd bn cm di en in ln ob p1 p2 sn sp x1 )
   ([color=BLUE]setq[/color] bn [color=MAROON][highlight]"myblock"[/highlight][/color]) [color=GREEN];; Name of block to insert[/color]
   ([color=BLUE]defun[/color] *error* ( msg )
       ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 'vla-object ([color=BLUE]type[/color] ln)) ([color=BLUE]not[/color] ([color=BLUE]vlax-erased-p[/color] ln)))
           ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-delete[/color] ([color=BLUE]list[/color] ln))
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'int ([color=BLUE]type[/color] cm))
           ([color=BLUE]setvar[/color] 'cmdecho cm)
       ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg [color=BLUE]t[/color]) [color=MAROON]"*break,*cancel*,*exit*"[/color]))
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg))
       (   ([color=BLUE]=[/color] 4 ([color=BLUE]logand[/color] 4 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 ([color=BLUE]tblsearch[/color] [color=MAROON]"layer"[/color] ([color=BLUE]getvar[/color] 'clayer))))))
           ([color=BLUE]princ[/color] [color=MAROON]"\nCurrent layer locked."[/color])
       (   ([color=BLUE]not[/color]
               ([color=BLUE]or[/color] ([color=BLUE]tblsearch[/color] [color=MAROON]"block"[/color] bn)
                   ([color=BLUE]and[/color] ([color=BLUE]setq[/color] bd ([color=BLUE]findfile[/color] ([color=BLUE]strcat[/color] bn [color=MAROON]".dwg"[/color])))
                           ([color=BLUE]setq[/color] cm ([color=BLUE]getvar[/color] 'cmdecho))
                           ([color=BLUE]setvar[/color] 'cmdecho 0)
                           ([color=BLUE]command[/color] [color=MAROON]"_.-insert"[/color] bd [color=BLUE]nil[/color])
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nBlock \""[/color] bn [color=MAROON]"\" not found."[/color]))
       (   ([color=BLUE]progn[/color]
               ([color=BLUE]/=[/color] 'ename ([color=BLUE]type[/color] en))
                            'paperspace
                            'modelspace
                   ([color=BLUE]vlax-invoke[/color] sp 'insertblock ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] in '(0.0 0.0 0.0)) bn 1.0 1.0 1.0 0.0)
Link to post
I put on code a litle question to got the Block Name:
(defun c:mymeasure ( / *error* bd bn cm di en in ln ob p1 p2 sn sp x1 )
   ;(setq bn "Botão") ; Name of block to insert ("myblock")
   [color=red](setq bn (getstring "\nEnter with block Name: "))[/color]
   (defun *error* ( msg )
     (if (and (= 'vla-object (type ln)) (not (vlax-erased-p ln)))
           (vl-catch-all-apply 'vla-delete (list ln))
       (if (= 'int (type cm))
           (setvar 'cmdecho cm)
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (cond
       (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))
           (princ "\nCurrent layer locked.")
       (   (not
               (or (tblsearch "block" bn)
                   (and (setq bd (findfile (strcat bn ".dwg")))
                           (setq cm (getvar 'cmdecho))
                           (setvar 'cmdecho 0)
                           (command "_.-insert" bd nil)
           (princ (strcat "\nBlock \"" bn "\" not found."))
       (   (progn
               (while
                       (setvar 'errno 0) (setq en (car (entsel "\nSelect object to measure: ")))
                       (cond
                           (   (= 7 (getvar 'errno))
                               (princ "\nMissed, try again.")
                           (   (= 'ename (type en))
                               (if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getendparam (list en)))
                                   (princ "\nInvalid object selected.")
               (/= 'ename (type en))
       (   (progn
               (initget 6)
               (setq di (getdist "\nSpecify length of segment: "))
           (setq p1 (vlax-curve-getstartpoint en)
                 p2 (vlax-curve-getendpoint   en)
                 x1 (abs (- (car p2) (car p1)))
                 sn (fix (/ x1 di))
                 x1 (+ (min (car p1) (car p2)) (/ (- x1 (* di sn)) 2.0))
                 ob (vlax-ename->vla-object en)
                 sp (vlax-get-property (vla-get-activedocument (vlax-get-acad-object))
                        (if (= 1 (getvar 'cvport))
                            'paperspace
                            'modelspace
           (repeat (1+ sn)
               (setq ln (vlax-invoke sp 'addline (list x1 0.0 0.0) (list x1 1.0 0.0)))
               (if (setq in (vlax-invoke ob 'intersectwith ln acextendotherentity))
                   (vlax-invoke sp 'insertblock (mapcar '+ in '(0.0 0.0 0.0)) bn 1.0 1.0 1.0 0.0)
               (vla-delete ln)
               (setq x1 (+ x1 di))
(vl-load-com) (princ)
Link to post
