Help with cut out
sledhockeyjock
Hey guy! So I'm new here and I was hoping you could help! I've at this for while, and I can't seem to do it. I'm trying to cut out this image (dragon 1-1) out of the solid (blade type 2). I've tired everything and every program and I can't do it, mostly because it always crashes...Can someone help? I cut need the black parts cut out all the way through the design.
Blade type 2.dwg
The dragon image could be pulled into AutoCAD and traced over using polylines. The polylines could be extruded.
The image file could be converted to a DWG file and opened in AutoCAD then extruded.
Bottom line...until you create the dragon in a form useable within AutoCAD you aren't going to get anywhere with it.
