missing graphite modeling tools
kayaan
hi friends i am facing some problems with graphite modeling tools.
in graphite modeling tools their is another tools ie. free form tools but in that ploydraw and paint deform tools are not their. i am unable to use that tools.please help me:unsure:
hi friends i am using 3ds max 2013 and i am newer to this software. i tried to make bed sheet for that paint deform tool is needed but under freeform tools paint deform tools are not showing, i tried to load the brush but nothing happen please help to recover this:)
Do you have your model selected? I'm not at my work computer right now, but I believe the tools will only be available when you have an object selected. If nothing is selected the tools will not be available.
  • 6 years later...
Hi! I had the same question... :) so after selecting the object and clicking freeform -> paint deform, for some reason it doesn't give me a paint deform toolbar breakdown with all the brushes so I can't choose anything to use. Can you please advise me what to do? Thank you!
It has been several years since I last used studio max and I don't have it installed anymore, so I can only take a guess. Is your object an editable poly, or do you have an edit poly modifier applied to the object? If it's just a standard primitive I don't think the paint deform tools will be available. If you post some screenshots I might be able to troubleshoot further, but for right now, that's about all I can offer.
