ksperopoulos
Remove Character From MText
ksperopoulos
I am trying to remove a hyphen from mtext. The hyphen will not always be in the same location. This is an example of what I am trying to do:
12-1/4" to 12 1/4"
Could someone point me in the right direction of how to achieve this please? Thank you.
Share this post
Link to post
Lee Mac
  • Prompt user to select MText (entsel)
  • Retrieve the MText DXF data (entget)
  • Retrieve the MText content (DXF group 1: cdr / assoc)
  • Retrieve the position of the hyphen in the string if present (vl-string-search / vl-string-position)
  • Remove the hyphen from the string (substr)*
  • Update the DXF data with the new content (subst)
  • Modify the MText entity (entmod)
*There are several alternative methods to approach this step:
  • Substitute the hyphen for an empty string (vl-string-subst)
Or:
  • Convert the string to a list of ASCII characters (vl-string->list)
  • Remove the hyphen character (vl-remove)
  • Convert the list of ASCII characters back to a string (vl-list->string)
Share this post
Link to post
ksperopoulos
Thank you Lee Mac. I will give these a shot and post an update later.
Share this post
Link to post
ksperopoulos
Lee Mac - This seems to work. Thank you for the help!
(defun c:testsize ( / obj lay sz1 sz2)
(vl-load-com)
(setq obj (entget (car (entsel "\nSelect Object"))))
(setq lay (cdr (assoc 8 obj)))
(setq sz1 (cdr (nth 9 obj)))
(setq sz2 (vl-string-subst " " "-" sz1))
(command "clayer" (strcat lay "-SIZE"))
(command "mleader" pause pause (strcat sz2 "\""))
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
