churchill
Select Blocks by Name & Attribute Property
churchill
I know that you can select all instances of a block reference by using QSELECT and specifying Block Reference and then where "Name" equals your given block name.
Is there a way to quickly select a block by name (exactly like the above), and then 'afterwards' reduce that selection down to just those blocks where attribute X is equal to a given string?
TIA
Share this post
Link to post
Murph_map
Look at the FILTER command, not easy to set up for a beginner but once you create the filter(s) you can save them with the dwg.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
