Tiger
The One thing you wish a new Drafter would know!
Tiger
I am wrapping up my first longer course in AutoCAD, now we have a few weeks of assigments to be handed in and some repetition to go through.
I want to leave the class with a good basic knowledge of AutoCAD and a sense of what the most common pitfalls is when it comes to AutoCAD.
So the question that I ask you, so that I can carry it on to them is:
Imagine you have a new employee. The boss gives her to you and says "teach her how to use this finnagled AutoCAD so that she can be productive ASAP!"
What is the one thing you want her to already know about AutoCAD? What is the most cardinal sin in your book? What is the thing you have tried and tried to hammer down your co-workers throat for ages?
TIA!
Edited by Tiger
Share this post
Link to post
ReMark
Don't draw everything on layer 0 then compound the error by overriding the color and linetype of every entity! Or else you're FIRED! LoL
Share this post
Link to post
PotGuy
Exploding everything down to a line when editing.
And what ReMark said.
Share this post
Link to post
dbroada
keeping the boss in hot coffee
Share this post
Link to post
Tiger
That should go without saying! :P
Share this post
Link to post
ReMark
Keeping the boss out of hot water (say what you are going to do then do what you said like "I'll have that drawing for you first thing tomorrow morning boss.").
Share this post
Link to post
JD Mather
TIA!
AutoCAD -
1. don't explode dimensions
2. draw 1:1
Field specific (mechanical)
1. We can't manufacture perfect parts - design and model with realistic tolerances and clearances.
2. The hole size for a threaded hole is not the major diameter of the fastener (Ex. do not use 10mm hole for an M10 thread...)
I'm sure each field (arch, civil...) have a similar commonly repeated sin.
Share this post
Link to post
ReMark
Very important: Which End Is Up.
Share this post
Link to post
Tiger
AutoCAD -
2. draw 1:1
I have some explaining to do about the Draw 1:1 concept thanks to another teacher... He told the class that You should always draw 1:1000, because that is the way we do it.
It took some time to explain to them that what he meant was the annotative scale should be 1:1000 as that is what the drawings will be printed in. And to explain annotative scaling to someone that doesn't fully grasp the "normal" scaling procedure was not easy. Add to that that we draw in meters in Model but in Millimeters in Paper so the scales are off anyway.... Scaling will be repeated again before we're done.
Share this post
Link to post
PotGuy
Tiger, you made my brain hurt reading that explanation for the 1:1000. Not because I don't draw 1:1, but because why would a teacher phrase it like that? :ouch: As you say, an extra lesson on scaling won't go amiss.
Share this post
Link to post
rkent
In no particular order.
Use layers
Use Osnaps
Paper Space and Model Space
Don't move existing geometry, the whole project is based off of an agreed upon base point for xrefs
Xrefs
Text height, fonts to use and not to use
How to edit blocks with attributes, no exploding blocks
Field:
Go into the field and ask questions, they know more than you do.
When shopping, dining out, etc. pay attention to how things are constructed
Share this post
Link to post
Tyke
I always say, in addition to the previous comments of others, that they should ask questions frequently and encourage them to discuss their projects, problems and ideas with their peers. We do it every day over a 15 minute coffee break in the afternoon, which often runs over. Then there is a single person responsible for taking ultimate decisions on how things are done in the company.
Share this post
Link to post
Dana W
I''d like my new drafters to have achieved at least a B in high school Plane Geometry.
Share this post
Link to post
Tyke
A good basic knowledge in geometry is essential. Being able to draw by hand on a sheet of paper is also a good plus.
Share this post
Link to post
nestly
I would advise them to spend time in the field as a blue collar worker so they have a practical understanding of what they're attempting to draw/model.
Share this post
Link to post
Dana W
Yes, and the hand drawing does not have to be freehand or pretty either, just clear and useful. The last thing I want in a technical chair is an artist.:lol:
Boss interviewing a brand new fresh PF drafting school graduate: "How many degrees are there in a triangle?"
Interviewee: "F or C?"
Share this post
Link to post
ReMark
The first thing my old boss used to do with every new chemical engineer hired right out of school was to make them sit at their desk and read through all the operations manuals. I told him that was the quickest way to kill their enthusiasm and make them regret they became an engineer in the first place. As soon as I could I'd rescue them from their cubicle-of-utter-boredom and bring them out in the field, take along a P&ID (process piping and instrumentation diagram) and go through every line on the drawing showing them what all those funny/weird symbols and lines represented. Then we'd go talk with an operator and have them explain how the process worked. It was much more informative and it really helped them to make the connection between the drawing, manual and equipment.
Share this post
Link to post
dbroada
that sounds like an apprenticeship - the sort that was common when I was a lad.
Share this post
Link to post
PotGuy
I'm currently doing an apprenticeship as a CAD Techy/Draughtsman. While the big boss want draughters in as much as possible, the senior draughtsman is pushing for more site visits.
Share this post
Link to post
RobDraw
Know drafting and be a drafter. Take the time to line up text, etc. Triple check your work to avoid showing your boss your stupid errors.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
