neko_designer
beginner - code help
neko_designer
hi, I just started reading about lisp and made my first "script", but it is giving me an error after drawing the first rectangle, and wont draw the next. can anyone tell me what am I doing wrong? thanks in advance
(defun c:pl()
(command "_thickness" 1 "")
(command "_circle" '(0 0 0) 1 "")
(command "_circle" '(10 10 0) 1 "")
(command "_rectangle" '(0 0 0) "_Dimension" 4 5 "")
(command "_rectangle" '(10 10 0) "_Dimension" 4 5 "")
(princ) ;;clean exit
Share this post
Link to post
pBe
(command "_rectangle" '(0 0 0) "_Dimension" 4 5[b] ""[/b])
command is waiting for input after "Specify width for rectangles : 5 prompt
Its either you replace the "" symbol with "\\" or pause for input
(command "_rectangle" '(0 0 0) "_Dimension" 4 5 "\\")
or provide a point list
(command "_rectangle" '(0 0 0) "_Dimension" 4 5 '(10 10 0) )
to place the rectangle of the first quadrant [right upper corner] as coordinate '(10 10 0.0) is north east of the rectangles first point
or even
(command "_rectangle" '(0 0 0) "_Dimension" 4 5 (polar '(0 0 0)  (* pi 0.25) 1))
HTH
And Welcome to the Forum neko_Designer
Edited by pBe
Share this post
Link to post
MSasu
Please pay also attention that all your command calls have an extra (the "") at their end.
(command "_thickness" 1 [color=red]""[/color])
(command "_circle" '(0 0 0) 1 [color=red]""[/color])
(command "_circle" '(10 10 0) 1 [color=red]""[/color])
(command "_rectangle" '(0 0 0) "_Dimension" 4 5 [color=red]""[/color])
Another potential source of errors will come from active OSNAP modes - need to disable them before inputting points:
(command [color=red]"_non"[/color] "_circle" '(0 0 0) 1)
Share this post
Link to post
Tharwat
I guess the OSNAP mode should be before the insertion point and not before the command name ;)
Share this post
Link to post
neko_designer
thanks everyone, you guys are great
Share this post
Link to post
neko_designer
Any idea why this doesn't work either?
(command "_arc" "_Center" '(0 0 0) '(1 0 0) '(0 1 0) "")?
I'm trying to create an arc only on the first quadrant on this case. In general, I have two points as well as the center point where I want it located and want to generate the arc
I could also work with angles of beginning and end of the arc and the center point.
I really appreciate any suggestions.
Share this post
Link to post
Tharwat
Try this ...
(command "_arc" "_C" "_none" '(0 0 0) "_none" '(1 0 0) "_none" '(0 1 0))
Share this post
Link to post
