CDJ3410
Section MV parts in Autocad MEP
CDJ3410
hi everyone, hope someone can help.
I am using Autodesk MEP 2014.
I have made an AHU by using MVparts, and am now trying to generate a section through the AHU and the associated ductwork.
The ductwork shows up fine, but the only thing that shows up for the MV part is the drain connector?
Is it possible to actually section and MVpart?
Share this post
Link to post
tzframpton
Can you upload the file?
Share this post
Link to post
CDJ3410
Tanner, thanks for your reply.
I had another look at this last night, found I could generate a section by using different settings within the section dialog box.
I think I was using the wrong display set up?, so I will hit the book again and see what went wrong.
The file is attached, so any advice or help you could give would be greatly appreciated.
Thank you
CDJ
https://www.dropbox.com/s/8vbc4d087vkdomc/P188-Ground%20Floor%20Plan%20-%20Standard.zip
Share this post
Link to post
CDJ3410
Thanks Tanner, i was playing around with this some more last night,
I found out i had used the wrong settings (display setup) in the section dialog box.
The part now shows in the section, i have attached a link to the drawing anyway, any help or comments you could offer would be greatly appreciated
CDJ
Share this post
Link to post
tzframpton
CDJ
Drawing looks good. Glad you got it working after all. :)
Share this post
Link to post
