br0604bom Posted January 11, 2014 Share Posted January 11, 2014 I has tried this with no success and I would be very grateful for some advice. I have looked at the sandbox tools and also tutorials but cannot find a good one. Do I need to raise all the lines to their heights and then look to generate the surface or can it be done straight from the 2d OS map? Thanks you to anyone with the answer Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 11, 2014 Share Posted January 11, 2014 If you want to create hills, your contour lines need to be at their correct elevations. If they are all at the same level, the program will not know how to create the terrain and will just generate a flat plane. You may want to take a look at this tutorial: http://www.sketchup-ur-space.com/2012/sept/learning-to-model-terrain-in-SketchUp.html Here's another good tutorial, but I'm sure you've probably already seen it: http://www.arch.virginia.edu/computing/training/online/faculty/stiles/pages/sketchup%20new/sketchup%207_sandbox%20tools.html Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 11, 2014 Share Posted January 11, 2014 Similar theme you have pts as text with Z value you can create 3d points from this info then create surface. Quote Link to comment Share on other sites More sharing options...
br0604bom Posted January 12, 2014 Author Share Posted January 12, 2014 If you want to create hills, your contour lines need to be at their correct elevations. If they are all at the same level, the program will not know how to create the terrain and will just generate a flat plane. You may want to take a look at this tutorial: http://www.sketchup-ur-space.com/2012/sept/learning-to-model-terrain-in-SketchUp.html Here's another good tutorial, but I'm sure you've probably already seen it: http://www.arch.virginia.edu/computing/training/online/faculty/stiles/pages/sketchup%20new/sketchup%207_sandbox%20tools.html Thanks very much Cad64, I had a feeling this may be the way it had to be done but was not sure as I have not really used it that much before, thanks for the links too. And thanks BIGAL, though I do not really understand what you mean Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13, 2014 Share Posted January 13, 2014 To clarify the plans turns up with all the levels/elevations written on it as text Yeah its 3d says the guy who sent it. You take the text value make it Z use the insertion point for X & Y create Autocad POINT with X,Y,Z. These points can then be read directly to make a surface Quote Link to comment Share on other sites More sharing options...
eldon Posted January 13, 2014 Share Posted January 13, 2014 To clarify the plans turns up with all the levels/elevations written on it as text Yeah its 3d says the guy who sent it. I think that the OP was confused, because his stated source (2d Ordnance Survey maps) are not digital plans, but the equivalent of paper plans. With these, all digital data has to be created, unless you can afford the digital plans. Quote Link to comment Share on other sites More sharing options...
br0604bom Posted January 13, 2014 Author Share Posted January 13, 2014 To clarify the plans turns up with all the levels/elevations written on it as text Yeah its 3d says the guy who sent it. You take the text value make it Z use the insertion point for X & Y create Autocad POINT with X,Y,Z. These points can then be read directly to make a surface thanks very much BIGAL, not confused eldon but thanks for your input, initially I meant the 2d maps as you mentioned but have since got the digital plans, still need the work done on them, thanks again Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 14, 2014 Share Posted January 14, 2014 Have you approached the local county they may if you ask nicely be able to supply a 3d model of the area. Quote Link to comment Share on other sites More sharing options...
br0604bom Posted January 14, 2014 Author Share Posted January 14, 2014 Have you approached the local county they may if you ask nicely be able to supply a 3d model of the area. I got a 2d map from them, the point is me to model it in 3d, though in saying that I never thought of asking for a 3d file!! Quote Link to comment Share on other sites More sharing options...
