pefi Posted January 20, 2014 Share Posted January 20, 2014 As in the title, expected result in attached drawing. I'm trying to change Origin X /Y, but that doesn't change the origin of the hatch. It there a setting that controls it? P.S. Is that drawing supposed to be 0.8Mb?? Funny enough purging made it even bigger hatch.dwg Quote Link to comment Share on other sites More sharing options...
resullins Posted January 20, 2014 Share Posted January 20, 2014 I believe you can highlight the hatch and move the round grip to the origin you want. Quote Link to comment Share on other sites More sharing options...
pefi Posted January 20, 2014 Author Share Posted January 20, 2014 It moves the whole hatch for me Quote Link to comment Share on other sites More sharing options...
resullins Posted January 20, 2014 Share Posted January 20, 2014 Hover over the grip for a second, and you should get a menu by your cursor that includes Hatch Origin. Select that and then select a new origin point. Quote Link to comment Share on other sites More sharing options...
pefi Posted January 20, 2014 Author Share Posted January 20, 2014 Thanks! I got there from right click menu and when i use "set origin" it works fine - that kind of solves my problem (trial and error to get it right, but at least I can modify the origin). However making changes in Properties window doesn't work - typing value, picking point, using calc to set value - none works. Quote Link to comment Share on other sites More sharing options...
irneb Posted January 21, 2014 Share Posted January 21, 2014 That is a bit strange, Could you try by using the HEdit command? It should bring up the old hatch edit dialog. Quote Link to comment Share on other sites More sharing options...
pefi Posted January 21, 2014 Author Share Posted January 21, 2014 That is a bit strange, Could you try by using the HEdit command? It should bring up the old hatch edit dialog. From hedit window: "Click to set new origin" doesn't change anything, but "Default to boundary extents" changes the origin. Does it work for you? Quote Link to comment Share on other sites More sharing options...
irneb Posted January 21, 2014 Share Posted January 21, 2014 Does it work for you?Yes it works fine for me in ACad 2014. Quote Link to comment Share on other sites More sharing options...
pefi Posted January 21, 2014 Author Share Posted January 21, 2014 Yes it works fine for me in ACad 2014. OK, looks like 2012 is broken or I have a broken installation (or using tablet somehow breaks this feature) Quote Link to comment Share on other sites More sharing options...
