Jozi68 Posted January 27, 2014 Share Posted January 27, 2014 I would like to delete a certain label style (that is used for surfaces) using vb.net code. Can someone help me please? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 28, 2014 Share Posted January 28, 2014 If you have a look into the sample files in 2012 they were there under I think ActiveX you should be able to find VBA example code that has a number of different CIV3d object creations obviously you should be able to do the opposite and remove. These examples seem to have disappeared in 2013+ Under the ribbon I think in 2012 it was introduced there is the ability to remove unused styles, this does what you want compared to say purge which will not remove styles. C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\en-us\Where_are_my_sample_files.html Quote Link to comment Share on other sites More sharing options...
