Costinbos77 Posted February 9, 2014 Share Posted February 9, 2014 (edited) Hello! Is there a mathematical method that can check if a point is inside an area bounded by a polyline? Graphic method by reporting point P (x, y, z) and then use ssget function to see if it is inside, is slower. Edited February 9, 2014 by Costinbos77 Quote Link to comment Share on other sites More sharing options...
cwake Posted February 9, 2014 Share Posted February 9, 2014 I wanted to research this one a while ago, and there is quite a lot of information out there on this question. Try google searches. I quickly found a thread at the swamp which may help. http://www.theswamp.org/index.php?topic=1890.0 But I think you'd even find this on Wikipedia. The most popular method seems to be send out a few rays at random angles and count the number of intersections. If none of the rays report an even number of intersections with the polygon then it has to lie inside. If I find any more links I'll post them. Quote Link to comment Share on other sites More sharing options...
ymg3 Posted February 9, 2014 Share Posted February 9, 2014 Costimbos, Have a look at this link: Efficient 2-D Geometric Operations by Carlos Moreno. ymg Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 9, 2014 Share Posted February 9, 2014 Here is a simple function implementing a ray-casting algorithm. However, note that this function does not test whether the ray 'grazes' a vertex - for example, in the following image the function will incorrectly determine the point as being outside the polyline since the ray intersects the boundary an even number of times. 1 Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks guys, it seems to be a common problem. Quote Link to comment Share on other sites More sharing options...
GP_ Posted February 9, 2014 Share Posted February 9, 2014 (edited) My offer... (defun c:test ( / poly pt Lv n) (if (and (setq poly (car (entsel "\nSelect a Polygon"))) (setq pt (getpoint "\nSelect a point")) ) (progn (repeat (setq n (1+ (fix (vlax-curve-getEndParam poly)))) (setq Lv (cons (vlax-curve-getPointAtParam poly (setq n (1- n))) Lv)) ) (alert (inside_p Lv pt)) ) ) ) (defun inside_p (list_vert / out_p cross on) (setq out_p (list (car (getvar "extmax")) (* 1.1 (cadr (getvar "extmax"))))) (setq cross 0) (mapcar '(lambda (a b) (if (or (equal (angle a ) (angle b) 1e- (equal a 1e- ) (setq on t) ) (if (setq : (inters out_p a b)) (setq cross (1+ cross))) ) list_vert (cdr list_vert) ) (cond ( on "ON" ) ( (> (rem cross 2) 0) "INSIDE" ) ( t "OUTSIDE" ) ) ) Edited February 10, 2014 by GP_ Updated code. Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted February 9, 2014 Author Share Posted February 9, 2014 Thanks GP_ look good. Quote Link to comment Share on other sites More sharing options...
juanragal Posted November 18, 2020 Share Posted November 18, 2020 Hi everyone. I does find GP's routine named Inside_p on this post, but I think it's not complet. I searched for more info on net and find complet code on other post. (defun inside_p (list_vert :p / out_p cross on) (setq out_p (list (car (getvar "extmax")) (* 1.1 (cadr (getvar "extmax"))))) (setq cross 0) (mapcar '(lambda (a b) (if (or (equal (angle a :p) (angle :p b) 1e-8) (equal a :p 1e-8) ) (setq on t) ) (if (setq :p: (inters :p out_p a b)) (setq cross (1+ cross)) ) ) list_vert (cdr list_vert) ) (cond (on "ON") ((> (rem cross 2) 0) "INSIDE") (t "OUTSIDE") ) ) It's great! but I find a error on use and I don't understand the causes... When I use your code on a USC and north orientation run correctly, but, when i change the plant view, with a Universal system coordinates too, do not work correctly and every time give me Outside... Maybe the extmax variable? Apologies for my english... Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted November 18, 2020 Author Share Posted November 18, 2020 list_vert = Global WCS , and (getvar "extmax") = Local UCS should be in the same Coordinates System. you need to convert them with (trans p 0 1) Quote Link to comment Share on other sites More sharing options...
juanragal Posted November 18, 2020 Share Posted November 18, 2020 You are right... Thank you Costinbos77 Quote Link to comment Share on other sites More sharing options...
