kristibaer Posted February 19, 2014 Posted February 19, 2014 First time/first time, please be patient with me. We have 6 custom toolbars that are compiled of individual toolbars and I need to edit the text in some of the "sub-toolbars" for a universal edit. For example, within toolbar "System-D", I have 8 custom toolbars. I need to change the text in toolbar 6 (which is subsequently used on other custom toolbars). This is an electrical drawing where I am changing a part number of a relay and 2 terminals. The text for all of these in in the same layer. AutoCAD help mentioned a means of maintaining cuix files externally, but I can't seem to find it and the person that created the cuix files is long gone. Thanks, Kristi Quote
Bhull1985 Posted February 19, 2014 Posted February 19, 2014 Are you trying to change the text that is displayed when you hover over a toolbar button? Or something within the actual drawing, like a block? Quote
kristibaer Posted February 19, 2014 Author Posted February 19, 2014 Our custom buttons are set up to turn on layers for specific features as well as turn off layers that conflict with the selected layer. I am trying to change the text when the layer is turned on, but there is nothing displayed when you hover over the button. Quote
Bhull1985 Posted February 19, 2014 Posted February 19, 2014 Okay it sounds like your button is loading a lisp routine and calling one of the functions from it. You will need to go into the CUI editor by pressing CUI into autocad Find the toolbar via selecting the correct menu from the top left dropdown and expanding toolbars, locating the one with your button. When you select it, it will show you (now in the right-hand pane of the CUI) where you can fill out all the information for that button, one of them should have something like: (load "somelisp-routine.lsp");somecommand; You will need to locate that file and edit it, there will be code within that starts with (prin and should have your text showing on the prompts within the (princ) line....that's where you'd edit it. HTH! Quote
BIGAL Posted February 20, 2014 Posted February 20, 2014 This is why I always create partial menus you have more control over changing things. There is some cuix to mnu routines out I have tried a couple of them. Search for CUI to MNU by Don Grout Quote
BIGAL Posted February 20, 2014 Posted February 20, 2014 I knew there was a bit more, make a copy of your cuix and rename it a ZIP file then open it up all you cui files are now exposed, try Menugroup.cui and run CUI to MNU on this extracted file. Quote
feargt Posted February 20, 2014 Posted February 20, 2014 a program like "notepad++" should allow you perform a search and replace for text in multiple files including cui files. Quote
