revit 2009 fatal error prompt
darris07
i got a copy of revit 2009 from the autodesk website. i installed the product and registered the copy. when i use the software after about 5 mins, a prompt shows stating that a fatal error has occured and that the program has to shut down. i dont have time to redownload the software again. is this problem fixable? what can be done?
I'd check the AutoDesk website to see if there is a "hotfix" for Revit 2009 that addresses the particular problem. There was something similar for vanilla AutoCAD 2008.
