Sengna Posted March 28, 2014 Author Share Posted March 28, 2014 The circle will absolutely, and without any variation, land exactly on top of the arcs if the center and radius is the same. What in the world is going on in that drawing? There's about a half meg of notes and things on OFF layers. Well, you have plenty of layers now. :wink: I zoomed extents and phhhhhhwwwwwp - nothing visible. Are you just practicing in an old dwg? It's OK, just wondering. Yeah, this drawing has so many things in it, it was from one of the project dwg, i did quite a bit of cleaning up before attach otherwise you guys won't be able to find it. Thanks Dana for your input. Quote Link to comment Share on other sites More sharing options...
Marvin7 Posted April 1, 2014 Share Posted April 1, 2014 If you only care that the arcs look joined, try using the BLEND command. It will draw a spline between them that supposedly will blend fairly intelligently. Quote Link to comment Share on other sites More sharing options...
