JADT Posted March 26, 2014 Share Posted March 26, 2014 I use publish to PDF from my drawings and I can get it to drop the file name as I rename all my layouts. When I need a directory of drawings published i have to open all the drawing in the directory and publish Is there a way to recreate dropping the filename when plotting to pdf through the plot screen..? it always adds the filename by default. So i have to rename each pdf. I want to eventually create a script for my batching program to run on entire directories of drawings...using standard dwg to pdf pc3 that doesn't add filename... Quote Link to comment Share on other sites More sharing options...
