tipu_sultane
How to seperate a dotted and full line of same layer?
tipu_sultane
In one diagram I found that line of same layer can be dotted or full.
I just want to ask how to make that and how to select them separately?
Share this post
Link to post
ROBP
right click in the drawing then choose quick select, choose linetype and choose line value then click ok all lines with value will be selected.
Share this post
Link to post
nestly
In most cases, it would be better to put "dotted" lines on their own layer rather than applying property over-rides, but as ROBP suggested, QSELECT will work, as will SELECTSIMILAR.
Share this post
Link to post
tzframpton
Also, look into the FILTER tool for a vast array of selection options, and the ability to save the selection for repeated and future uses.
Share this post
Link to post
tipu_sultane
Thanks.
Good, I think there should be an option also for filtering different colors of the same layer.
Share this post
Link to post
nestly
There is, but again, if objects are different enough that they need to be a different color, then they're different enough to deserve their own layer.
Share this post
Link to post
tipu_sultane
There should be different layer, but they don't wanted to do so because doing so Its needs little time for me. Anyway politics.
Thanks.
Share this post
Link to post
ReMark
That's a pretty poor excuse for not putting the lines on a separate layer. It would take maybe all of 15 seconds to do.
There is nothing worse than trying to edit a drawing where the originator decided to override layer settings and assigned different colors and linetypes to objects. Denoting "ByLayer" and sticking to it is always the better CAD drawing practice.
Share this post
Link to post
