Flatshot and Rotate
curtie20
If you read the link I posted previously (see post #41) regarding viewports you would understand there are two types: model viewports (a.k.a. - tiled) and layout viewports (a.k.a. - floating).
You should be using the MVIEW command in your paper space layout to create a viewport for each object.
F.Y.I. - Within the thread the first link takes you to is another link regarding viewport scaling. It too is worth reading as well.
  • Replies 132
  • ReMark
    52
  • curtie20
    51
  • Dadgad
    13
  • JD Mather
    9
Posted Images
Remark do I have to create the viewports 1st in paper space and then draw the objects cause I'm very confused and that is why I turn to yourl
No, you do not have to create the paper space viewports first.
You turn to me? OK. Then do me a favor. Read the nice little synopsis I put together about viewports I gave you the link for in post #41. Then come back here with any further questions. Go. Now. Do. I'll wait.:whistle:
You aren't all the way there yet but you have made progress.
I would recommend setting the viewport scales to 1:8 then I would lock the viewport displays so the scale cannot be accidentally changed. The red lines in the 2D representation should appear dashed should they not? Your viewports should be on their own layer set to "no print" in the Layer Properties Manager.
Getting closer.
Ideally viewports should be on their own layer (not layer 0) and their display locked. Anyone, including yourself, could try working through a viewport and inadvertently change the scale.
The viewport layer can be set to "no print" (i.e. - red diagonal line through printer icon) in the Layer Properties Manager.
All this was covered in the link I previously provided and mentioned more than once.
I dont know what I did wrong cause I created to new layers for the 2 viewports and in the layers and in the layers property manager I locked both the layers and set both to no print
You locked the layers; you did not lock the viewport display. There is a difference. One of the places this option can be found is on the Properties palette. Did you not see/click on/read the link in the viewports article I wrote? I think I'll have to start leaving a trail of breadcrumbs for people to follow.
1. It looks like both viewports are on layer 0.
2. Your 2D view created with the Flatshot command is not quite right. It is somewhat distorted. This is primarily due to the location/rotation of your UCS when you used the command.
I think I got it right now
Your view of the flatshot objects is skewed, giving a shortened view. Prior to using flatshot
Set an iso view like SW
Set UCS to World
run flatshot...
To see the flatshot objects change to a top view
In PaperSpace, create the viewport, change to a top view if it isn't already there, adjust view and scale, etc.
My Project.dwg
I accessed the Display Locked option using another method (highlight/right-click on viewport frame(s).
Note the difference between my 2D view created using the Flatshot command and yours. Doesn't mine look closer to the overall shape of the 3D model? That's why, early on, I said you would be better off using the ViewBase command rather than Flatshot. ViewBase will give you better, more predictable, results on the first attempt than Flatshot will.
That should be right now, fingers crossed
Afraid not, see post #62, follow along with the steps provided.
Also, don't use the linetypes that start with acad_iso_..., scroll further down to see the ones that work with imperial units.
Edited by rkent
The instructor wants flatshot, I have to follow instructions
I will wager the instructor will not even know the difference. (see my response from 11 days ago) At this rate you will not get very far along in your experience with AutoCAD.
If the instructor did know the difference - the instructor would not have you fooling with flatshot.
Use viewbase, take your chances and move on to next problem.
Which kind of begs the question, "Where is your instructor? Flatshot or viewbase, this is an 11 minute problem."
Ahh I see, I got confused - you have moved onto next problem.
