edoll
Pop-up Option for Selecting Linework on top on one another
edoll
I had my AutoCAD set up so when I had multiple polylines on top of one another, I could just click the line and a small ("quickoption" maybe?) window popped up displaying the different layers that each line was on and I could select the line I was wanting to edit.
Well, this disappeared (maybe I hit an "F" key) and now I can only select the line that is on the top or select all of them (sometimes I'll have 3-4 lines on top of one another and have them on different layers).
Does anyone know how I can bring this setting back? I hope this is clear...as its challenging to type this issue in a search (as far as wording goes).
Share this post
Link to post
RobDraw
That's called selection cycling. There is a button for it on the bottom of the window or Ctrl+W will toggle it.
Share this post
Link to post
edoll
Hooray! I couldn't find the button anywhere at the bottom - I probably have that toolbar not displayed...but the shortcut works great!
Share this post
Link to post
RobDraw
It's here.
Share this post
Link to post
ReMark
The area pictured above is called the Application Status Bar. It is not a toolbar.
Share this post
Link to post
RobDraw
Thanks for the correct name. I couldn't remember what to call it.
Share this post
Link to post
ReMark
And here is another tidbit for the OP. Type STATUSBAR at the command line. A value of "1" will turn it on and a value of "0" will turn it off. Good to know if you are ever a contestant on Jeopardy and one of the categories is AutoCAD. LoL
Share this post
Link to post
danielk
the easiest way i use :
1) turn selectionpreview (autocad variable ) to 3.
3) use shift+spacebar to toggle between objects.
Share this post
Link to post
RobDraw
Where is #2?
I used to use shift+spacebar for selection cycling and always found it cumbersome but found the pop-up window very annoying. We recently upgraded AutoCAD and I decided to give the some of the OOTB settings a go. I am more tolerant of pop-ups than I used to be and may be keeping this one.
Share this post
Link to post
danielk
Where is #2?
theres no 2 , sorry my mistake:?
Share this post
Link to post
Dadgad
In order to display the SELECTION CYCLING icon on the Status Bar,
access it in the APPLICATION STATUS BAR MENU, in the STATUS TOGGLES drop down in the lower right hand corner of your screen.
I like the pop up menu much more than cycling with the spacebar. If the object which is highlighted blue on the list, is the one you want,
then there is no need to do anything more than hit ENTER, as the software has
preselected it for your consideration, which if not overriden will be applied.
Edited by Dadgad
Share this post
Link to post
