andy_lee
Judge cad version,If version is too low,not loader and prompt.
andy_lee
I have a table routine, need cad 2005 later version,
If routine call command is "test" , so call "test" , frist, judge cad version ,if CAD2005 previous versions, not run and Pop-up prompts.
Edited by andy_lee
Share this post
Link to post
hmsilva
Something like this perhaps.
(if (<= (atof (getvar 'ACADVER)) 16.1);; "16.1" AutoCAD 2005
   (Alert
     "Need CAD2005 or later"
   (exit)
hope that helps
Henrique
Share this post
Link to post
andy_lee
   (Alert
   (exit)
hope that helps
Henrique
hmsilva, Thanks, but not that.
Your routine is when "appload", check cad version and Pop-up prompts.
I mean is after appload, after input command in the command bar, after press Enter or space key, check cad version.......
Share this post
Link to post
hmsilva
andy_lee,
you shouldn't have edited and removed the code that you had posted at msg #1...
That code is not my code, is yours, I just modified it to work with AutoCAD 2005 or later ones...
If I understood you correctly, perhaps something like this
(defun c:test ()
  (if (>= (atof (getvar 'ACADVER)) 16.1);; "16.1" AutoCAD 2005
    (progn;;; your routine here
      (Alert "You have the correct CAD version!!!");; just for demo
    );; progn
    (Alert "Need CAD2005 or later")
  );; if
);; test
HTH
Henrique
Edited by hmsilva
Share this post
Link to post
Lee Mac
Here are some other properties/functions/system variables which may also help:
(vla-get-caption (vlax-get-acad-object))
(vla-get-version (vlax-get-acad-object))
(getvar 'acadver)
(getvar 'product)
(getvar 'program)
(getvar '_vernum)
(ver)
(_ver)
Share this post
Link to post
andy_lee
andy_lee,
(defun c:test ()
    );; progn
  );; if
);; test
HTH
Henrique
hmsilva, Thank you!
like this?
(defun c:[color="red"]test[/color] ()
;;;;;;;;;;;;;;;;;;;;;;;;My routine is start ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun c:[color="red"]test[/color](/ *error* dlg p a i l 1p sc e pl h gr rot r)
;;;;;;;;;;;;;;;;My routine is over;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    );; progn
  );; if
);; test
1.Command must be the same? your routine command is "test", my routine command must "test" too,
2. if version is right , show "you have the correct cad version" ,this can omit.
I mean if version is low ,show "Need Cad2005 or later" ,if is right , not prompt,Direct calling program.
Thanks!
Share this post
Link to post
andy_lee
(getvar 'acadver)
(getvar 'product)
(getvar 'program)
(getvar '_vernum)
(ver)
(_ver)
Thanks ,lee ,how to Judge Express Tools is install ?
Share this post
Link to post
hmsilva
hmsilva, Thank you!
like this?
(defun c:[color=red]test[/color] ()
(defun c:[color=red]test[/color](/ *error* dlg p a i l 1p sc e pl h gr rot r)
    );; progn
  );; if
);; test
Thanks!
One way:
(defun c:test (/ *error* dlg p a i l 1p sc e pl h gr rot r)
 ;; first test AutoCAD version
    (progn;; if test returns T
;; your routine start
;;your routine end
    );; progn
   ;; if test AutoCAD version returns nil
  );; if
);; test
HTH
Henrique
Share this post
Link to post
andy_lee
One way:
Thanks hmsilva,
;;your routine end
[color="red"] );; progn ;;I delete this , OK! Otherwise an error[/color]
  );; if
);; test
Share this post
Link to post
hmsilva
You're welcome, andy_lee!
Glad you got it to work.
Henrique
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
