LosGirk
On error checking...
LosGirk
Is it necessary to put error checking in a program that doesn't change any variables? In other words, does it do more than just the resetting of user settings if a cancel/escape occurs? Thanks
Share this post
Link to post
LosGirk
Is there anybody out there?
Share this post
Link to post
neophoible
You don't have to do error checking. It is up to you. However, if the program can go wrong, it helps to have the error checking instead of just crashing or returning nothing, leaving the user confused and frustrated.
Share this post
Link to post
LosGirk
Alright thanks neophoible,
So if I'm hearing you right, it's good practice to at least have the "An error occurred, user settings reset" line so as to not leave someone hanging and just good cleanly courteousness. Thanks for stepping up.
 (princ  "\nAttention! An error has occurred!")
   (princ  "\nFWTCAD  RCALC now restoring the user enviroment.")
8)
Share this post
Link to post
hmsilva
Error handling,
is not only to reset system variables, is advisable to use an error handling function whenever we access an external file (txt, xls, ...) to open, to read or to write, to ensure that the file is properly closed on failure, if not, the external file will remain marked as "opened" and to access that file again, you will have to close the AutoCAD session and start a new one...
The same is applicable in ObjectDBX and other objects created, to release objects on error...
HTH
Henrique
Share this post
Link to post
LosGirk
Thank you hmsilva
Share this post
Link to post
hmsilva
You're welcome, LosGirk
Henrique
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
