tplight Posted July 24, 2014 Share Posted July 24, 2014 Does anybody have any idea if a lisp routine can be created so that if a block (detail .dwg) is inserted from a detail library that a hyperlink can be added to the block as it is being inserted so that the hyperlink can be used to later open the detail.dwg in it's remote location. We're looking to use extensive folders/sub-folders to organize our detail library and do not want to browse through many folders/sub folders when searching for the block in question. (Side note... We don't use xrefs to attach details to detail sheets as we like to edit attribute text within the block). Using Autocad Architecture 2014..... Many thanks for your help! Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted July 25, 2014 Share Posted July 25, 2014 hi tplight, i'm not sure but can try command: Field -> Linked -> Hyperlink ? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted July 25, 2014 Share Posted July 25, 2014 Do you have any sample block ? Quote Link to comment Share on other sites More sharing options...
