tahano50
command dialog box
tahano50
In searching the help I keep seeing snippets of dialog boxes for certain, some commands that I am use to dealing with on the command line.
Is there some place to turn on these dialog boxes?
I do a cross between 2d and 3d so some dialog boxes would be most helpful.
I've tried the filedia but it seems to deal mostly with open, save.
Thank you for your help.
Share this post
Link to post
Murph_map
Try CMDDIA =1
Share this post
Link to post
MSasu
Welcome to the Forum, Tahano50!
For an exact response it will be useful to post the names of these commands.
Share this post
Link to post
BIGAL
Filedia 0 or 1 on or off, if you have off use ~ to force on as temporary a little gem of not known info. Note some commands are frustrating very hard to turn dialogs off.
Share this post
Link to post
jarr3tt88
You could put the - in front of the command and it should give you the command line version
ie -purge, -hatch
and if you still want the button version, you can edit the macro line of that button in the CUI. Just add the -
And if you like hotkeys, I'm not sure if you can just edit this in the pgp file to add the - infront.
Hope this helps
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
