tahano50 Posted July 28, 2014 Share Posted July 28, 2014 In searching the help I keep seeing snippets of dialog boxes for certain, some commands that I am use to dealing with on the command line. Is there some place to turn on these dialog boxes? I do a cross between 2d and 3d so some dialog boxes would be most helpful. I've tried the filedia but it seems to deal mostly with open, save. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
Murph_map Posted July 28, 2014 Share Posted July 28, 2014 Try CMDDIA =1 Quote Link to comment Share on other sites More sharing options...
MSasu Posted July 29, 2014 Share Posted July 29, 2014 Welcome to the Forum, Tahano50! For an exact response it will be useful to post the names of these commands. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2014 Share Posted July 29, 2014 Filedia 0 or 1 on or off, if you have off use ~ to force on as temporary a little gem of not known info. Note some commands are frustrating very hard to turn dialogs off. Quote Link to comment Share on other sites More sharing options...
jarr3tt88 Posted July 29, 2014 Share Posted July 29, 2014 You could put the - in front of the command and it should give you the command line version ie -purge, -hatch and if you still want the button version, you can edit the macro line of that button in the CUI. Just add the - And if you like hotkeys, I'm not sure if you can just edit this in the pgp file to add the - infront. Hope this helps Quote Link to comment Share on other sites More sharing options...
