aggie_moose
print to pdf inconsistency
aggie_moose
Hello all,
I have been working on printing to text-searchable PDFs, and ran into a little problem. When I regen a drawing and print to PDF, the output is not consistent - it changes just a little bit from plot to plot. This is unacceptable to the client, who is very picky about their drawing packages.
Can anyone reproduce this problem? I attached a script and a drawing that shows what I mean. I put both in C:\test\, then opened the drawing and loaded the script.
The result is 10 pdfs saved in that folder, each one a little bit different. The right most line is sometimes outside the print area, sometimes inside. It seems completely random. The only code that runs between plots is
(command "undo" "mark" "-purge" "all" "*" "no" "-overkill" "all" "" "done" "-purge" "all" "*" "no" "regen" "undo" "back")
But how on earth could that change the drawing?! Furthermore, why does it change the drawing in a way that's inconsistent? If it was shifting things around, that's one thing, but to sometimes change things and sometimes leave them alone? I feel like my computer is non-deterministic :(
example.dwg
print.lsp
Share this post
Link to post
MSasu
As I can see in your code you were using Extents to indicate the area to plot and Fit as scale. Please pay attention that this will be influenced by anything you may have located outside drawing's frame!
(command "-plot" "y" "model" "DWG To PDF.pc3" "ANSI expand B (11.00 x 17.00 Inches)" "i" "l" "n" "[b][color=magenta]e[/color][/b]" "[b][color=magenta]f[/color][/b]" "1.1,0" "y" "monochrome.ctb" "n" "w" "C:\\test\\test0.pdf" "n" "y")
I suggest you to look using instead Window (since you were printing from Model Space), respectively a ratio (i.e. 1:1); this will produce consistent results. For sure it requires also consistent designed drawings - drawing frame always in the same spot.
Share this post
Link to post
eldon
Might this be a case where setting and plotting to Limits could lead to a consistent output. :?
Share this post
Link to post
aggie_moose
I did try setting limits and printing to limits instead, using this code before each print
(mapcar 'setvar '(LIMMIN LIMMAX)
   (mapcar '(lambda ( x ) (reverse (cdr (reverse x))))
     (mapcar 'getvar '(EXTMIN EXTMAX))
But the print output still varied from plot to plot.
MSasu, unfortunately when this drawing package was made, the border block was not dropped in the same place. Sometimes it was exploded, sometimes it was scaled differently, sometimes it's the A3 ratio and sometimes it's the 11x17 ratio. On some drawings, all the font was set to a huge font using mtext tags and the view was scaled to 1/8 size so that it looked right. (Some of the drawings were done entirely in comic sans, but that's another issue). I could not imagine how a drawing package could be LESS consistent. So using the window is not really an option, unless you know of a way to set it reliably.
Share this post
Link to post
MSasu
Setting the limits to EXTMIN / EXTMAX system variables then using Limits as print area is just equivalent with using Extents. I think that Eldon was considering setting the limits manually in each drawing, thus evaluating their content.
But, to stop us guessing, it would be very useful to actually post an example on what you mean by aforementioned variations. Since you were printing to PDF make screen-shots of two outputs and mark the trouble-maker differences.
Share this post
Link to post
aggie_moose
Ah ok, yes I believe that would work. There's around 7000 drawings in the project, though, and setting the limits for each manually would be very time-consuming. Additionally, though it pains me to say this, setting the limits is a bit too advanced for some of our CAD users. I've even gotten complaints that typing a single command to run a script was too confusing (they wanted a button on the ribbon).
Here's a gif showing the 10 pdfs that were made with the lisp I provided. each one was plotted using exactly the same settings. The problem is when it wanders too far to the right and part of the border is outside the print area.
http://i.imgur.com/b4Tax0Y.gif
Share this post
Link to post
aggie_moose
Here's another example. It's not just the border that moves around, it's everything in the drawing. It's as if the print coordinates change a bit whenever you undo a purge and a regen. It's not the regen command that makes it change, it's the purge, regen, undo. This leads me to believe that somehow "undo" isn't actually undoing everything... something is different from plot to plot.
http://i.imgur.com/ztf1ZOx.gif
Of course, this is only speculation. I have no clue what's going on :huh:
Share this post
Link to post
