danielk Posted August 3, 2014 Share Posted August 3, 2014 Hello Although i get this message :Transmittal created: C:\Users\dsa\Desktop\400131045 - Standard.zip. I cant file the file in this location . i try to etransmit a different location but again i don't see the file ? im trying to solve this problem for an hour , didn't find anything suspicious in the etransmit setup definitiion , anything like it used to be . Thanks Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 3, 2014 Share Posted August 3, 2014 Hello Although i get this message :Transmittal created: C:\Users\dsa\Desktop\400131045 - Standard.zip. I cant file the file in this location . i try to etransmit a different location but again i don't see the file ? im trying to solve this problem for an hour , didn't find anything suspicious in the etransmit setup definitiion , anything like it used to be . Thanks Are you signed on as user dsa? If not, you will not see that desktop. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 3, 2014 Author Share Posted August 3, 2014 yes . signed in as *dsa*.. Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 3, 2014 Share Posted August 3, 2014 yes . signed in as *dsa*..Try a Windows search for the file name 400131045 - Standard.zip. Since I can't see your computer, there is not a lot else I can do to help. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 4, 2014 Author Share Posted August 4, 2014 Try a Windows search for the file name 400131045 - Standard.zip. Since I can't see your computer, there is not a lot else I can do to help. wow! i found (here : C:\Users\dsa\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\Recent\Specify Zip File) a shortcut to all the files i tried to create etransmit , but its a shortcut! and when i click on it i get a windows message of missing shortcut . Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 4, 2014 Share Posted August 4, 2014 Check the properties of a shortcut to see if it is pointing to that same location that you were trying to use before. If it is, try a location other than your desktop, like a folder on your C: drive to see if it works. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 5, 2014 Author Share Posted August 5, 2014 tried many locations , same problem Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 5, 2014 Share Posted August 5, 2014 From the information given: The file is being created. A shortcut is also being created. (I verified that AutoCAD creates the shortcut.) The file is being deleted (or possibly hidden). Could this be from having anti-virus or malware protection settings being too high? Zip files could be tagged as a threat and handled automatically according to the applied settings. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 5, 2014 Author Share Posted August 5, 2014 From the information given: The file is being created. A shortcut is also being created. (I verified that AutoCAD creates the shortcut.) The file is being deleted (or possibly hidden). Could this be from having anti-virus or malware protection settings being too high? Zip files could be tagged as a threat and handled automatically according to the applied settings. actually i dont have any protection on my pc Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 5, 2014 Share Posted August 5, 2014 actually i dont have any protection on my pc Why not? There are plenty of free programs that work very well. You could be infected and not even know it. In fact, that may be why you are having this problem. If it were my computer, I would get the free programs from AVG, Malware Bytes, and SpyBot and immediately scan using all three of them. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 5, 2014 Author Share Posted August 5, 2014 Why not? There are plenty of free programs that work very well. You could be infected and not even know it. In fact, that may be why you are having this problem. If it were my computer, I would get the free programs from AVG, Malware Bytes, and SpyBot and immediately scan using all three of them. im installing now AVG .. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 5, 2014 Share Posted August 5, 2014 Report back after doing all three scans. While AVG is very good, it may not get everything. I've seen it detect things but not be able to fix them. That is why I suggested the other two. AVG is the only one I keep active. It blocks just about everything. The other two I use for scanning/fixing only. Quote Link to comment Share on other sites More sharing options...
danielk Posted August 5, 2014 Author Share Posted August 5, 2014 Report back after doing all three scans. While AVG is very good, it may not get everything. I've seen it detect things but not be able to fix them. That is why I suggested the other two. AVG is the only one I keep active. It blocks just about everything. The other two I use for scanning/fixing only. installed avg and malware bytes , removed the threats , but still the same . Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 5, 2014 Share Posted August 5, 2014 The only other thing I can think of is that the files are being hidden somehow. Do you see any other .zip files? Quote Link to comment Share on other sites More sharing options...
danielk Posted August 5, 2014 Author Share Posted August 5, 2014 yes i see other zip files . even new ones i create with winrar... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 5, 2014 Share Posted August 5, 2014 I still got nothing else. If you get it figured out, please post back here. I am very curious as to how this is happening. Quote Link to comment Share on other sites More sharing options...
danielk Posted September 6, 2014 Author Share Posted September 6, 2014 after a month of trying to find a solution , i decided to uninstall Autocad and reinstall . i also removed all autodesk products from my PC (inclduing registry leftovers) but still, im unable to create etranasmit what am i missing . its something with windows 7 maybe ? Quote Link to comment Share on other sites More sharing options...
danielk Posted October 24, 2014 Author Share Posted October 24, 2014 anyone? maybe there's a solution to this problem ? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 24, 2014 Share Posted October 24, 2014 Check the file path that the shortcuts are pointing to. It could be a clue. Are you on a network and possibly do not have write privileges to the directory? Quote Link to comment Share on other sites More sharing options...
danielk Posted October 25, 2014 Author Share Posted October 25, 2014 im not on a network its a stand alone station . the shortcut are pointing to the same location i sent the etransmit to.. if i click on the shortcut and "open folder location" windows doesn't find it . Quote Link to comment Share on other sites More sharing options...
