MathU41 Posted September 5, 2014 Share Posted September 5, 2014 I'm working on a project to have 3D printed. My first real attempt at 3D drafting and I've left off the 2D for a few years, so bare with me. Using AutoCAD 2015. I have this cross shape, hit Extrude, select Mode, Solid, I select everything, specify a distance, and get an outter surface. I can highlight the inner lines, too, and it will do the same thing to the triangles, but form the circle into a solid cylinder. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 5, 2014 Share Posted September 5, 2014 A cylinder has an inside & outside radius ie two circles. press pull ? Quote Link to comment Share on other sites More sharing options...
MathU41 Posted September 5, 2014 Author Share Posted September 5, 2014 Finally got it. Tried using the press-pull, and eventually had to erase all my fillets and reapply them. Looks like they had a tendency to disconnect when I moved things. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 5, 2014 Share Posted September 5, 2014 Extrude a line and you get a surface. Extrude a closed polyline and you get a solid. Extrude a circle and you get a solid. Use PressPull on a profile comprised of lines, arcs, splines and/or polylines or any combination of the four and you'll get a solid. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 5, 2014 Share Posted September 5, 2014 Nobody mentioned it - but there is something wrong with your original profile. If you had attached your dwg file here - someone would have found the problem for you. Quote Link to comment Share on other sites More sharing options...
MathU41 Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks for clearing some stuff up, guys. Like I said, my first crack at 3D drawing. Once I got that down, I finished up the drawing. It will need adjustments before I have it 3D printed, but it turned out perfectly as a demonstration. The prototype will be hand-fitted anyway. Mr. Mather, I had no idea I could upload the .dwg's here! I'll do that in the future, thanks! Quote Link to comment Share on other sites More sharing options...
