aminkovskaya
Need help asap
aminkovskaya
image.jpg I don't understand how to do it. Help?
Share this post
Link to post
ReMark
Start the LINE command and input the coordinates given in the exercise. Something like this....
Command: L
LINE
Specify first point: 1.5,1
Specify next point or [undo]: 2.1717,1
Specify next point or [undo]: 2.7074,1.75
Specify next point or [Close/Undo]: 4.5,1.75
Specify next point or [Close/Undo]: 4.82,1
Specify next point or [Close/Undo]: 5.5,1
The result of the above should look something like this...
Share this post
Link to post
ReMark
Did you get it figured out? Yes? No? Maybe?
Share this post
Link to post
aminkovskaya
Not really...
Share this post
Link to post
aminkovskaya
How would I find out the answers to the question after I do that?
Share this post
Link to post
Bill Tillman
Of course being a LISP developer, I'd have done it this way:
(defun c:test ()
 (setq a '(1.5 1)
b '(2.1717 1)
c '(2.7074 1.75)
d '(4.5 1.75)
e '(4.82 1)
f '(5.5 1)
g '(4.1838 4.0711)
h '(3.5071 3.81)
j '(3.7974 3.3861)
k '(3.6304 3.3139)
l '(2.8125 2.25)
m '(4.2843 2.25)
 (command "._LINE" a b c d e f g h "c")
 (command "._LINE" j k l m "c")
 (command "._TEXT" a "" "" "a" "")
 (command "._TEXT" b "" "" "b" "")
 (command "._TEXT" c "" "" "c" "")
 (command "._TEXT" d "" "" "d" "")
 (command "._TEXT" e "" "" "e" "")
 (command "._TEXT" f "" "" "f" "")
 (command "._TEXT" g "" "" "g" "")
 (command "._TEXT" h "" "" "h" "")
 (command "._TEXT" j "" "" "j" "")
 (command "._TEXT" k "" "" "k" "")
 (command "._TEXT" l "" "" "l" "")
 (command "._TEXT" m "" "" "m" "")
 ); end function
Sure make things simpler when you let the computer do all the work. However, your class instructor may not see it that way! :nono:
And actually there's no need to draw the object since the question is using AutoCAD commands what is the length of line a-h, you could just do this at the command line:
Command: (setq a '(1.5 1) h '(3.5071 3.81))
Command: (distance a h)
which could also be shortened to
Command: (distance '(1.5 1) '(3.5071 3.81))
Your instructor may be okay with this since the question is how far from point a to point h.
Share this post
Link to post
ReMark
Not really...
What seems to be the problem? You start the line command, and type in the X/Y coordinates as presented in the exercise. So your first set of coordinates are entered on the command line as 1.5,1 then you press the Enter key. After that it is just a matter of entering the coordinates followed by pressing the Enter key as quickly as you can until all coordinates have been entered which should return you to the starting point. That takes care of the outline. Follow this up by restarting the line and entering the four sets of coordinates, in the same fashion, for the inner part of the letter.
Bill: The OP has trouble understanding how to enter coordinates in AutoCAD and yet you think he/she will understand what to do with the lisp routine? That's a real leap of faith in my opinion.
Edited by ReMark
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
