How to Edit Dynamic Blocks
Tahir Qayyum
I have some dynamic blocks in an old file. I am trying to use the same blocks in another file with some modifications. But when i try to edit it in block, it still remains the same. Can anybody guide how this is possible or what command I should instead of Bedit?
It still remains the same? Meaning what exactly?
Attach one of the dynamic blocks, as a DWG file, to your next post and give us an example of one thing you would like to change about it. Someone here will take a look at it.
In this attachment, I have a block. I want to erase the text that says 7/100 % and change the color of red line. But when i open it in block editor, the whole block is still intact as unit.
Now that sounds like somebody inserted the block into the block editor.
