Swihfr01 Posted December 15, 2008 Posted December 15, 2008 Hello, I use AutoCAD 2005 to create assembly drawings. Then I use Print Screen and a screen capturing program ("Gadwin Print Screen" Google for free download) to create a jpeg. Finally I paste the pic into word (2000) to create instructions. Is there an easier/better way to convert drawings to pictures? Quote
BOB'27T Posted December 15, 2008 Posted December 15, 2008 See if this will be of help: http://www.cadtutor.net/forum/showthread.php?p=194168 Quote
MaxwellEdison Posted December 15, 2008 Posted December 15, 2008 Yes, specifically the JPGOUT command, not sure if it is available in 05 however. Quote
Swihfr01 Posted December 15, 2008 Author Posted December 15, 2008 Yes, specifically the JPGOUT command, not sure if it is available in 05 however. Jpgout works in 05 thanks. Does anybody know how to change the background to white? I've seen it done b4 but it's been forever-ago. Quote
MaxwellEdison Posted December 15, 2008 Posted December 15, 2008 Format->Options->|Display(tab)|->[Colors(button)] Quote
Swihfr01 Posted December 15, 2008 Author Posted December 15, 2008 Thanks guys you've been awesome. One more question: is there a way to toggle between white and black backgrounds? I prefer to work with a black background but I'll need to change it to white to "take the picture". I could use the Layout tab; but line styles (dashed lines) don't show up. Quote
GypsyQueen Posted December 15, 2008 Posted December 15, 2008 Thanks guys you've been awesome. One more question: is there a way to toggle between white and black backgrounds? I prefer to work with a black background but I'll need to change it to white to "take the picture". I could use the Layout tab; but line styles (dashed lines) don't show up. I'm suspecting that there's probably a lisp that could be written to do that, but I'm definitely not fluent enough in ACAD for that at all. Perhaps if we're lucky, we might get a lisp writing god to add his thought here. :wink: Quote
MaxwellEdison Posted December 15, 2008 Posted December 15, 2008 Linetypes will still work, just change your linetype scale. Remember that paperspace is a WYSIWYG environment. Edit: WYSIWYG - What You See Is What You Get Quote
CarlB Posted December 15, 2008 Posted December 15, 2008 For toggling background, see routine in this thread: http://www.cadtutor.net/forum/showthread.php?t=863 Quote
Swihfr01 Posted December 16, 2008 Author Posted December 16, 2008 For toggling background, see routine in this thread: http://www.cadtutor.net/forum/showthread.php?t=863 Does anybody know of a walk-through for adding a "VL Routine" like the one in this thread to CAD? I've had some experience with Visual Basic so I have rudimentary knowledge of programming, but I've never tried to do something like this. Quote
dbroada Posted December 16, 2008 Posted December 16, 2008 Thanks guys you've been awesome. One more question: is there a way to toggle between white and black backgrounds? I prefer to work with a black background but I'll need to change it to white to "take the picture". I could use the Layout tab; but line styles (dashed lines) don't show up. I have 2 profiles set up, one with black screen, one with white and just select the most appropriate profile. Quote
matt41129 Posted December 17, 2008 Posted December 17, 2008 If you are going to export a image. My advice.. Print a High Res (300dpi) PDF and drag that into photoshop. They save it down to a jpg. You will get a much better Hi-Res Jpg. Some Food for thought... I have recently done alot of assembly drawings for custom units and i found that a quick 3D in sketchup showing the parts is a slick way of doing that. I got a jpg from that and imported into cad and did my detailing from there. The drawings turned out pretty good. Quote
